HTC Sensation 4G Logo
A
Anonymous Posted on Jun 21, 2014
How to Cancel predictive text - HTC Sensation 4G
2answers
How can I turn off predictive text on Doro 5680.
It sounds like you have followed the correct procedure, but make sure it is 'auto-correct'.
https://www.google.com/search?q=Doro+5680+turn+off+predictive+text
Enable predictive text on mobi wire ogima no information on user manual how to enable predictive text Thank you
I don't know about enabling predictive text on mobi wire ogima. However, in other mobiles, it is enabled by going to setting > language and enable the predictive text. I hope it works.
May 09, 2020 • Cell Phones
How do I disable predicted text on an alcatel 2038X cell phone?
To turn OFF predictive text mode, press and hold the # key.
To turn ON predictive text mode, press and hold the # key. The icon at top-left (next to abc, Abc, or ABC) moves right.
Alternatively
Enable or disable predictive text
From the home screen press the Menu button. Move the cursor to Message and press the OK button.
1helpful
How to turn off predictive text from asus tranformer notebook?
To turn off predictive text, go to Settings - Language and Keyboard - Touch Input - Text Input - Prediction.
Then select On or Off - See more at: http://www.phonetipsandtricks.com/tips/samsung-galaxy-note/turn-off-predictive-text-38/#sthash.MPTR2fvE.dpuf
1helpful
I cant seem to remove the predictive text from mt text messages.
While writing a message, go to
Option > Predictive Text > Set the Predictive Text to Off.
Or simply
Go to Menu > Tools > Settings > Language > Predictive Text (set it to off)
2answers
Blackberry texting prediction problem
what exactly is the text problem...here are some general solution for text prediction
  1. options > auto text > edit > clear the with field ( this solution is used for instance if you keep type hr and it comes out as hour and you want to change that)
  2. options >auto text > new > enter word ( used to add a new word to auto text )
  3. options > SMS > disable auto text : YES ( used to disable auto text or test prediction )
4helpful
I cant switch predictive text on
For you to switch to predictive text or T9, just go to your "Text Message" window, when on that application window please select on your "options" button on your cell phone.
You'll have a pop up with scroll options that would either say 'predictive text', just ok the T9 or "Predictive Text" option and you would be able to have predictive text switched on.
Kind Regard
4helpful
2answers
Predictive text comes onto phone automatically every time I write a message-how can this facility be cancelled?
menu >> messages >> write message >> options >> writing language >> Dictionary off
or
Press and hold the # key
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
