I think you have the european version, which is the adf doesn't able to read the fls size. A paper longer than a4/letter will be detected as legal. It was the firmware of the copier that makes this problem.
The solution is : You can "shift" the result, by pressing "additional function" than "shift", press "<-" (left) before make a copy with adf source. The result will be shifted up about 0.9".
And the bottom page will be still copied as well.
good luck.
Hi im jules_09.have you set the paper size first before copying.there is nothing wrong with adf its fine.if you want to use fls go to the program then set the size of the paper and which tray you are going to use each paper tray can be adjusted according to your paper size needs
