The remote does not work. I have checked the key locks in the settings and they are set to off so I don't suspect them to be the problem! Have turned tv off at wall socket and back on? Any ideas? Where can I buy a replacement?
SOURCE: ViewSonic N3250W Locked
Yeah, my 19 year old daughter did the same thing. I found a solution on the 2750W thread
http://www.fixya.com/support/t115143-tv_just_flashes_different_colors
Solution - just press Menu, Enter and Power buttons at once.
SOURCE: ViewSonic N3250W will not turn on
Do you get a red standby light at all? If not, I'd look first for the standby transformer as being defective. There may also be a fuse right by the AC power cord. Look around inside and update this with your results. Post whether or not there is a standby. We'll need to go step by step on this one.
Dan
SOURCE: all buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
SOURCE: my viewsonic tv will not
Try disabling the lock by pressing and holding [1] (menu) and the down arrow on the front panel for 10 seconds or so. This toggles the power lock on and off for several Viewsonic monitors.
I hope this helps.
SOURCE: TV will not turn on
iF THE SET is a year or even two old and you have to repeatedly turn it on and on but once it is on it is ok, the problem is in the set's power supply.
All of these sets (every brand) have a "standby Power supply" built into them, it runs 7/24 even if the set is not turned on. One of the areas some companies cut corners on is the filter capacitors in this part of the set: Say the constant voltage is 9 volts and they use 10 volt rated caps, the caps will fail after a year or two from heat.
The reason companies do this is the cost difference say on 10,000 sets between 10 volt versus 16 volt rated caps is a nice piece of money.
If someone opens it and follows the power cord to the supply it will be easy to see, these caps (see photo) have a perfectly flat silver top with creases---any caps puffed up are bad.
Look at the caps and Before you rate this information let me know what you find, this problem will not just go away and usually gets worse and worse until the unit will not turn on at all.
SD TECH
