Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
A
Anonymous Posted on Jun 22, 2014
A spring feel out of the clippers when i went to clean them..can .you show me how it gose bacl
Whale rechargeable dog clippers
2 Related Answers
Anonymous
  • 10 Answers
  • Posted on Aug 03, 2010
SOURCE: blades fell off oster dog clippers but can't fit
With the hinge of the clipper facing you:
Make sure hinge is open, if it is not, prize it open with a flat head screwdriver.
Slide the blade on with the blade siz/number faceing you.
Snap shut.
If this fails, try again, but push the latch in as you snap them shut.
If this fails, you may need repair!
www.sheareaseltd.com
Anonymous
  • 23 Answers
  • Posted on Aug 25, 2011
SOURCE: I was shaving my dog
With most clippers, after an amount of use they need to be cleaned then oiled. Most sets come with some amount of oil for your clippers. Otherwise you can purchase it separately. This should fix the problem.
1helpful
How to change heiniger clipper blade support
No adjustment needed but you must make sure the spring ends from the hinge are pushed into the two holes either side on the latch. If your still having trouble give us a call.
http://www.angliaclipperservices.com/dog
2answers
The mounting hinge will not raise on my clippers when I push up on the button below the blade
whilst pushing the release button (latch) you must also pull the front of the blade away from the clipper.
God dam spring fell out of the dam clipper when i went to clean the heads
Looks like you are in the poo then because nobody will be able to help you without knowing exactly what model you are talking about.
How do I find what model my Andis pet clipper is
On the back of the clipper it should say something like AG, AGR, or AGC does it look like any of these dog clippers Dog Clippers .
Has it got a power cable or is it a Rechargeable? Also age is a good clue?
Instructions on how to clip my dogs hair.
  • Set the dog hair clippers to the 9-10 setting. Use this setting to clip your dog's undercarriage. Undercarriage refers to your dog's armpits, **** area up to the tail, and stomach.
  • Set the clippers to the 7-8 setting. Clip your dog's legs and paws with this setting.
  • Use a comb to pull your dog's hair away from the eye and muzzle area. Set the clippers back to the 9-10 setting and clip all around his face, ears and head.
  • Rinse your dog with clean water or give him a shampoo to remove all of the excess hair you clipped off. Blow drying him may be necessary if it's during the colder months of the year.
  • 1helpful
    A5 dog clipper or blades may need tune up or
    some times the link and gear inside the front part of the clipper wears out and the blades just wont cut. try this, remove the clipper blade on the front of the clipper their is a lever color red grab this part with your 2 fingers and move it side to side if it moves and feel sloppy your gears and link are worn out. you need to replace, also check the hinge for spring tension. if you need help Contact [email protected]
    12helpful
    3answers
    Andis pm-3 dog clipper won't cut anymore!
    I have had this same problem!  I bought new blades, sharpened old ones, and nothing worked.  Finally, I went to an authorized service center and they couldn't figure it out.  Then the tech. pressed on the blade (the outside bottom one) and it cut!  When you remove the blades with the 2 big screws, there are 2 more smaller screws inside under the smaller blade.  One of those was not screwed in tightly.  That was all it was!  I guess they jiggle loose.  I hope this helps!
    peony
    Top Oster Health & Beauty Experts
    shaveroutlet.com
    shaveroutlet.com
    Marc Messenger
    Level 1 Expert
    jws1013
    Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
