PXE-E61:Media Test Failure, check cable
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
So, if you have any USB sticks or attached HDD's that do not have an install image remove them and reboot.
If the HDD has an operating system installed and it still won't work after removing any USB storage, check that the HDD is functioning properly.
SOURCE: PXE-E61: media test failure check cable
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
SOURCE: GETTING ON MY LAPTP: PXE-E61: Media test failure, check cable
This error message can be caused by a faulty connection to the hard drive or a faulty hard drive or a faulty disk controller.
Go into the BIOS configuration to see if it has detected the hard drive, if it is not detected that is why the laptop won't bootup.
To confirm or check if the hard drive is faulty, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port (you may need assistance from a computer savy friend).
If this computer cannot see this as an external drive then it is faulty. If the computer can see this drive as an external drive and you can open the folders and files on the hard disk then the hard drive is OK and the fault is probably a faulty disk controller on the laptop. A faulty disk controller is part of the motherboard and the only fix is a replacement motherboard. This may not be a cost effective solution and it may be better to put your money towards a new laptop.
SOURCE: PXE-E61 : Media test failure,
You gotta a bad hard drive and it's not recognized when the computer is powered up. The ZE2000 uses good old 2.5", 9.5mm(height) ATA/IDE drives and the stock drives are of the slower variety (4200rpm rotation speed) - it's probably easy enough that anyone can get a new one (and a faster one of 5400rpm or 7200rpm) and replace it within a minute or two. Best source for these things is by mail: buy 'em on Amazon or eBay and in general, don't pay over 50 cents per gigabyte or you'll look like a tourist.
HP puts out its service manual online, so I'll just pass along the link (this may or may not be for your exact model, but for hard drive replacement, it's all the same): http://h10032.www1.hp.com/ctg/Manual/c00442578.pdf
HDD replacement is page 110, I believe. Removing and installing a hard drive should take no more than 120 seconds.
Of course, you'll have the load Windows after the installation, and that'll take roughly 60-90 minutes.
SOURCE: pxe-e61: media test failure, check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
