This definitely means that you have no signal input to the TV. Check the signal input and switch to the source input that you provide, like cable or antenna.
The TV has different inputs modes, the TV tuner being on of them, another mode(s) will accept an input from the input jack(s) on the back, front or side of your TV. Look for and source button or input button on the front of the TV, press it waiting a few seconds between each push until the picture returns.
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
if your tv has no AV IN AND OUT connections, purchase a converter from eletronic shops just around your area.
this will make you convert AV into RF signal and feed that to your tv. you have to go on a channel and search for right frequency the will search for you.
What input did you connect the satalite to? Probably one of the
'video' inputs I'm guessing, which means you have to select that video
source using the 'INPUT' button on your remote. (Some makers use
different names but you get the idea)
Hope Ya Fix it!
