Control panel stuck on 99 minutes. wont turn on. have tried unplugging for periods of time. does not reset
SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
SOURCE: maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
SOURCE: my maytag front loader will not drain water oe comes on the control panel
On the 9700s it's even easier - three screws on the front bottom panel below the door, then use your hand to unscrew the large round handle in the front center. When you can't unscrew any more, pull gently and the filter / catcher will come out.
It's amazing how much stuff mine held - 4 breastfeeding shields, a pencil, a pen, a fake mouse, and lots of grey gunk.
Screw it back in, put the panel back on, and you're in business.
SOURCE: MAYTAG NEPTUNE DOOR LOCKED WILL NOT OPEN!
The comment posted 14 may 2009 it what helped me. DO NOT PRY OPEN the door. Find the release cord inside the soap dispenser,,,you may have to remove the 4 screws and lift it from the washer like i did. I had to lean into the door and pull the cord to release the lock. It was not a system error. The washer was over loaded and although the door was closed and locked...the load pushed the door enough to indicate that it was open and would not wash. After opening the door, rearranging the load and removing some, the door closed and latched locked and was able to continue with the wash. DO NOT PRY OPEN,,,use the cord release first,,,this worked for me.
SOURCE: Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
