SOURCE: Emprex LM 1905 DOES NOT COME ON NOT EVEN THE LIGHT
1. Change the power cable for the monitor and see if it comes on
2. If it does not come on, do one more test and hook up this PC to another computer
3. If the Monitor works on another PC, then the problem is with ur PC - start by changing the VIDEO CARD
SOURCE: Emprex monitor lm 1905 - blacks out after a
see repair emprex ebay item 300447533053, one was a weak back light needed replacing, test by using 3 out 4 with a spare to make the 4 out of 4 (if you have two lcd, just disconnect one panel completely and link 1 into the other inverter without dissassembling the pannel ! ie [=i=] - [==] to find or see if back lights, it's a bit young for the capacitors to go (1 or 2 years) , else over heating , try out of case on a plastic sheet or similar for the pcb side to rest on reassembled, I used this plus tape stuck it on the back of the pannel ie pannel, plastic sheet pcb's then power and vga connected , solved an over heating on a 2year emprex , LCD as just 3 parts and the casing, ps the high voltage parts with shock your hands don't touch when switch on!
5 times later still getting shocked, reaching in to adjust the vga ribbon!!!
