LG DLE2514 Electric Dryer Logo
A
Anonymous Posted on Jun 22, 2014
I have power to dryer. It it won't tirn on
1 Related Answer
Anonymous
  • 43501 Answers
  • Posted on Aug 12, 2011
SOURCE: Lg model #dle0332w dryer won't turn open it up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
1helpful
LG electric dryer model DLEO332W or DLE0332W
Sounds like the belt broke..."loud thump"
Sep 21, 2013 • Dryers
tip
DLG5932W Service Manual
Some sites make you pay for it... but I found it FREE.
Here --> http://www.appliancefactoryparts.com/content/pdfs/129227-8.pdf
Also applies to:
DLE5911W
DLE2511W
DLE5932W
DLE5932S
DLE2532W
DLE0332W
DLG5911W
DLG2511W
DLG5932W
DLG5932S
DLG2532W
DLG0332W
on Apr 29, 2009 • LG DLG5932W Gas Dryer
heatman101
Jul 29, 2011 • LG Dryers
LG Electric Dryer (DLE0332W) change all thermostats, HEATING ELEMENT, THERMISTOR, MOISTER SENSORS, HOUSE CIRCUIT BREAKER BUT STILL WONT HEAT AT ALL
Hi hamptonmd,
If you have replaced all those parts, and it is still not heating, the problem is most likely the Main PC Board (Comes in 2 parts, front electronic and back electronic)
To test if this is the problem, activate the T/D and test if power is going to the element in cycle, use an advanced current protective multimeter to do this. If no power goes to the element at all, then the PC board is not providing power to it, thus it is faulty.
Hope this helps :-)
If you found this solution helpful, please rate it accordingly :-)
May 11, 2011 • Dryers
DLE0332W--dryer continually runs like its in wrinkle free mode. Will not complete regular dry cycle.
You may have an issue with the control board and it will not shut down once the cycle has been completed. You will need a qualified LG technician to diagnose the problem.
Good luck
LG dle0332w dryer won't turn off automatically when set to Cotton/Towels mode
You may have an issue with the control board. You will need a qualified LG tech to diagnose your problem.
Good luck.
Sep 22, 2010 • Dryers
Lg dryer not drying dle0332w.
I would check the heating element. Hope this helps. You can take the back off but make sure it is unplugged... The heating element is in the tube long box. Hope this helps. Heating elements are easy and cheap repairs. Hope this is what is wrong.
Dec 10, 2009 • Dryers
2answers
My dryer will turn on will not tumble just makes this humming sound. I can make it run my turing it mannualy. Model DLE0332W
sounds like the belt from the motor that goes aroud the tumbler is bad, i would replace the belt and check the tensioner while your in there
May 11, 2009 • Dryers
1helpful
How do I remove the front panel from an LG DLE0332W electric dryer. It is kicking the circuit breaker and I want to check the drum rollers.
Hello alloyd1455,
Please find a link for the service manual for your dryer and note page 26 and up discusses how to open up and gain access to the inside compartment.
Hope this helps
http://136.166.4.200/contents/Laundry/DLE0332/DLE0332_Service_Manual.pdf
Regards,
Rick
Top LG Dryers Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Dryer Expert? Answer questions, earn points and help others
