hinges seprately cannot be replaced . for support needs you can call hp tech support team 1800-474-6836 ask for printers and ask for the same. if its under factory warranty the entire printer can be replaced//
Hi. The hinges are either broken or worn out. It is possible to replace them but it can be difficult to find them. I recommend calling around to a few local repair shops as they may have an old one of your model that they are using for parts. Here is a link that shows you how to replace a hinge http://www.insidemylaptop.com/repair-replace-broken-hinges-hp-pavilion-dv9000-notebook/
Check out this WEB site on how to replace a hinge on a laptop. It may not be exactly the same model as your laptop but the principles are the same, Click on this link :- http://www.insidemylaptop.com/
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
You LCD hinge weared and teared too hard. So these is a interstice on your right hinge. You need a new hinge. You can find the hinge on ebay. and below is a replace manual. h10032.www1.hp.com/ctg/Manual/c00530488.pdf
