There is a problem with the mic of your device. It is quite normal for your mic to experience certain problems like poor transmission of sound and it is also a normal happening if the mic gets covered or blocked by tiny particles like dust. The following steps should be taken, if the problem persists after doing them, then you may have to send it for repairs. 1. Use a sharp pointed object like a needle to clear the opening of the mic. Be sure to do this carefully and not to push the needle all the way in as doing this could permanently damage the mic. 2. Also, check your phone or mic settings if the mic volume has been set to a very low level that it is affecting your audibility. 3. Lastly, make sure that the mic is not close to any source of noise and is not to far from the phone while you are making the call. In other words, ensure perfect connection between the phone and the headset. If the problem persists after doing this, then you have to send it for repairs. Hope this was helpful?
If the other person can hear you, then the problem is with the earpiece on the phone. The phone rings using another speaker on the base unit. Swap the mic/earpiece handset unit with another phone and use with existing base unit, to narrow down the fault.
There is some problem with your phone mic only.please use your headset to check it.Connect your headset and answer phone with your headset.If the person don other side hear you then the problem is with the mic only.Please take the mobile to NOKIA CARE centre and they will repair the mic.
The yellow colour swiggly object which comes next to the battery bar is nothing unusual.It shows that your call is been connected with the person on other side.This symbol will not appear when the other person's phone is ringing,When the person picks up the phone this yellow colour symbol will apear.]
Dear, its ur mic problem,claim ur warranty if ur fone is in warranty or u hav to to some certified mobile fone repairer to change ur mic.its not very expensive mic is very cheap so don't worry.
your cell phone microphone is in loose contact or it is gone ...
so just open the handset and check for the mic ,if it is in loose contact then refit it properly so that the mic pins contact the motherboard of you cell ... if the mic is dead then you replace the mic with the another one ..
mic is available very much cheaply so do it if you are good at opening the handset ..
if you are afraid of opening it then just contact the technician he will make it for you .. technician may charge some service charge that s all .. it is very minor problem ..
any doubts you can reply me i am always here to assist you thank you bye please rate my solution
lo m8
sounds like ur mic is faulty or possibly u could have a software problem.try to replace your mic or get ur fone reprogramed.if you dont want to try your self then try these guys they good an cheap.
http://www.mobilephoneservicecentre.co.uk/
