According to the Kyocera service manual it is the following:
Machine number mismatch. Machine number of main
and engine does not match. Data damage of EEPROM.
Contact the service Administration division.
It would appear that the flash memory is corrupted.
Testimonial: "well the machine is now grounded....it needs a new board. thanks by the way, it was helpful"
This is a machine serialnumber mismatch between to EEprom's
Testimonial: "that`s true indeed. thanks by the way"
SOURCE: Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
SOURCE: how do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
SOURCE: error llama 7410 0013444 impresora kyocera ecosys
Drum unit non- installing error
The drum unit is not installed or not
installed properly.
The drum PWB EEPROM does not communicate
normally.
Causes:
- The drum unit is not installed.
- Defective connection drum PWB (YC1) and connect-L PWB (YC3).
- Defective drum PWB EEPROM.
- Defective engine PWB.
Check procedures/corrective measures:
- Install the drum unit
- Check the connection of connectors drum
- Replace the drum unit
- Replace the engine PWB
SOURCE: KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
