Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Red light on printer button on and message reading follow instructions in right cover to remove. I follewd the instructions and the message is still displayed what do i do to fix? it wont allow me to copy print or scan
    New Friend:
  • 31 Answers
Hi! If there is a printer with door problems, this is one! Lets presume you have a paper jam, even if you dont see it. The bit of paper can be stuck in this three points: paper cassete, register sensor and fusion sensor.paper sensor gets damaged very often in this machine but the message will be " out of paper". The register sensor ( it tells the machine the paper arrived to the register roller and it can start cordinate paper movement with scanner movement, a question of syncronous efforts),lyes in the right cover, it looks like two small eyes, they must be cleaned. The fuser sensor, tells the machine the paper arrived there without problems but also says it already got out, once the paper comes out. the fusion must be opened to check this.
Now, this machine have problems in the door switch, you will see a square hole at the left side of the machine (presuming your facing it with the right door open turned to you) somewhere at half way.theres a switch inside that is actuated by a proeminence in the right door, once closed. If this actuator is broken the machine will keep telling you "close right door".If you see its broken, insert a small screw diver and press in, the machine will start to work and the message disapears, If the case, you have to "Reconstruct " the actuator, in order to touch and actuate the inner switch. Sometimes i do this just puting a screw through the plastic. Other choice is to order a new cover, these actuactors are very fragil. Also the latch that keeps door well shut.you wanna try to push the right door in, sometimes is enought. Hope i been helpfull, sorry my (bad) english. Come to me again if you got no improvement.
Posted on Jun 24, 2014
6ya staff
SOURCE:
Anonymous
SOURCE: ricoh 2015 printer
The B is saying there is a jam in the right hand side of the machine. You may have fuser stripper fingers popped out of place causing it to jam or you may have a torn off piece of paper stuck between the registration rollers. Try spinning the black and silver rollers by hand and see if any paper comes out.
Posted on Oct 09, 2007
Anonymous
  • 38 Answers
SOURCE: A follow instructions in right cover to remove
U JUST FOLLOW THAT INSTRUCTION TO REMOVE THE MISSFEED
Posted on May 17, 2009
quennie732
  • 422 Answers
SOURCE: Follow instructions in right cover to remove
open the right door right in front of your PCU are 2 long rolls a black and silver turn these by hand so the torn paper between them comes "up" -Carl
Posted on Jul 12, 2009
joel_baleta
Joel Baleta
  • 155 Answers
SOURCE: Follow instrctns in right cover to remove
is it a miss feed problem? open the cover on the right cover of the machine then remove the jammed paper. then close the covers
Posted on May 31, 2010
Ronil Singh
  • 126 Answers
SOURCE: Keeps showing follow instrctns in right cover to
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
Posted on Jan 04, 2011
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Samsung 4623FN when i refill the catrdige second time it shows me as. End of Life replace with new catridge..
  1. Prepare a new cartridge of the color (K, C, M or Y) you wish to replace.
  2. Ensure that the printer is on with all covers closed, and that the Toner Low warning, Sleep, or Ready status is displayed.
  3. Press the right%20arrow%20black.jpg Right arrow button to display the menu.
  4. Press the up%20arrow%20black.jpg Up or down%20arrow%20black.jpg Down arrow button to scroll through the options until Reset Menu is highlighted:
  5. Press the right%20arrow%20black.jpg Right arrow button once, this will enter the reset menu as shown below:
  6. Press the up%20arrow%20black.jpg Up or down%20arrow%20black.jpg Down arrow button to scroll through the options until Change Toner X (where X is K, C, M or Y) is highlighted for the toner you wish to change:
  7. Press the Right arrow button to start the removal procedure. The printers panel will read Please wait, then after a short delay the printer should display a red error light and the message Replace Toner X, where X is the relevant toner cartridge:
  8. Open cover D.
  9. Hold the toner cartridge knob and tilt it toward you.
  10. Remove the empty toner cartridge from the printer.
  11. Take the protective materials off of the new cartridge, and gently shake the new toner cartridge a few times.
  12. Take the new toner cartridge out of its package, and remove the plastic protective cover from the toner cartridge.
  13. Insert the new cartridge into the printer.
  14. Close the toner cartridge cover.
  15. Close cover D.
  16. If you need to change another toner cartridge, repeat the above procedure from Step 1.
TO view pics of the steps click here
Apr 19, 2011 | Samsung SCX4623F Laser All-in-One Printer
Tow red signal
  1. Make sure the printer is turned on, then open the printer cover.
  2. Do one of the following:
    • If the red error light is on, press the Maintenance button.
    • If the red error light is flashing, press the Maintenance button. You see Ink Cartridge Replacement, highlighted in the Advanced Settings menu. Press OK.
  3. You see a message on the LCD screen telling you that ink cartridge replacement will begin. Press OK to continue. The print head moves to the replacement position.
  4. Open the cartridge cover.
  5. Press in the tab on the back of the cartridge and lift the cartridge out of the printer.
  6. Lower the cartridge back into the holder, with the green circuit board facing the front. Then gently push the cartridge down until it clicks into place.
  7. Close the ink cartridge cover.
  8. Press OK and close the printer cover.
    The printer begins charging the ink delivery system.
  9. When you see a message that charging is complete (after about a minute), press OK.
Dec 06, 2010 | Epson STYLUS R230 InkJet Photo Printer
The following is diplayed on the printer. "Ink system has failed,. Sytem cannot print. Error oxc18a0201. Turn off to prevent damage." Printer is a HP Photosmart C8180 All-in-one.
Hi, You can use this link to solve printer problem.
h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&tmp_track_link=ot_recdoc/c01130468/en_us/c00551397/loc:1&lc=en&dlc=en&cc=us&product=3204788
Hope it helps.
Nov 01, 2010 | Office Equipment & Supplies
Ink system failed. error message Oxc18A0001. Turn power off then on again Have done this but message still reappears
Please perform the below resets
1.
Press & hold the power button > unplug the power cable from the back of the printer while holding the button for 30 seconds > plug the cable back then release the button.
2.A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
Reset the All-in-One to the factory default settings by using these instructions:
1) Press Red Eye Removal & Print Photos button simultaneously
2)Enter Special Key Combo is displayed on the screen.
Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
Display should say "Support" and display the FW rev XXXXX.
3) Press Right Arrow button untill "Reset Menu" is displayed. Press OK.
4) Press Right arrow untill "Semifull Reset" is displayed.
5) Press OK.
Oct 04, 2010 | HP Photosmart C6280 Printer
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
Keeps on giving the following message "Read instructions in right cover to remove" There no paper there at all but this keeps coming up.
pls look again. i also experience it turn the lower knob downward to push the paper several times located om the tray on the right side. hope this help.
Jan 23, 2010 | Ricoh Aficio 450 Copier
The Align cartridges keeps poping up on the printer window after every use and then it dose a test ..and i cant figure out how to fix the Align i also just put in a new cartrige.. help me please
To resolve false error message, follow the below instructions.
1.Press and Hold the “Print Photos” & “Red Eye Removal” buttons. Release both buttons. Display should say “Enter Special Key Combo”
2.Press and release in sequence “Red Eye Removal”, “Print Photos”, “Red Eye Removal”
3.Press and release the right arrow button until the display says “System Configuration Menu”. (on C8100 use Touch Screen)
4.Press and release the “OK” button.
5.Display should say “Support”. Use the Right arrow Key to look for "Reset Menu".
6.Press and release the “OK” button.
7.Press the right arrow key to look for "Partial Reset", press 'OK'
The printer will go off and will power on by itself, else wait for 20 seconds and power on the printer to complete reset
Dec 23, 2009 | HP Photosmart C5280 Printer
Fast blinking red light, message says cartirdge service station is stuck
Solution
Follow these instructions to adjust the clutch on the printer.
Disconnect the USB cable.
Press the printer power button to turn off the printer.
Disconnect the power cord from the back of the printer.
Open the top cover of the printer.
Remove the print cartridges from the printer.
Slide the cradle to the right side of the printer.
Locate the clutch on the left side of the printer.
NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal.
Figure 1: Printer clutch
Remove the rear access door from the back of the printer.
Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
Release the clutch and roll the wheels up two more rotations.
Reinstall the rear access door.
Reinstall the print cartridges and secure the latches in place.
Close the top cover and reconnect the power cord.
Turn on the printer.
Print a test page.
NOTE: If the printer continues to display a Print cartridge cradle is stuck message or make grinding noises, click "contact hp" on this page for more support options.
May 26, 2009 | HP PhotoSmart 7660 InkJet Printer
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
278 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
