Http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#delime
Code 1L is scale build-up. Delime heat exchanger.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
SOURCE: I have a richmond tankless water heater and its
1/overheat stat 2/ fan 3/diaphrapm valve 4/ micro switch check area around fan very small hose pipe for pinhole best of luck
SOURCE: Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
SOURCE: How can I get an owners manual for a Richmond's
Try this link.
http://demandware.edgesuite.net/aabh_prd/on/demandware.static/Sites-Appliance-Site/Sites-CompactAppliance_Primary/default/v1298033256538/pdf/ownersmanuals/rheem/RTG74IndoorOutdoor_owners.pdf
