SOURCE: 98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
SOURCE: Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
SOURCE: stackable w/d will not drain or spin
You will need to replace the switch I am afraid. If I had your Model # I could get you the part # . If you would like to order a swtich, I can give you my web site address
I would appreciate if you would rate my prfomance here because I am new to this site. Any feed back on how I am doing would be helpful.
Thanks
Vic
SOURCE: Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Hello Tina Kaha - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
