Delta Machinery has two 36-750 saws on their support site; please check the label to determine if your saw is T1 or T2. If you start here: http://www.deltamachineryparts.com/ , you can look up the model number for most Delta tools. The link to the instruction manual will be on the right side of the specific product parts page, below links for various parts diagrams.
The two saws use the same instruction manual. The direct link to the manual is http://www.deltamachineryparts.com/documents/instruction_manuals/En422-35-651-0011.pdf . (Note: this manual also is for the 36-755.)
hi friend
there was prooblem in video satge u have do do this get a tacnision to repair it u have chage curcuit bord ic so u have to take ur tv in a repeir shop then he chnge the ic & ur problem will solve
Hello, You could have a bad water temperature sensor. There are usually 2 and one works the dash gauge while the other controls the "Limp Home mode". The "Limp Home mode" is used to limit the heat build-up so the motor stays cooler. It also makes it so the engine can not go faster and get hot enough to ruin the motor.
The 2 sensors work independently so one can show one thing and the other sensor can do something else. If the dash gauge shows you are getting hot, then that is another matter. It would mean that the engine is not cooling and the cooling fan is not working properly or you are out of water.
The way the vehicles are built, there should be a indicator light to show a problem. You can get a FREE scan of the truck at Autozone, Oreilys, or Advance autoparts. It would be a good idea to do this and while you are there, the person helping you can point to where the sensors are, just ask.
You have your calculator set to give your answer in scientific notation. If you would like it to give your answer in decimal form you need to change the settings. On my calculator which is an older version, you just press [mode] three times. On your screen you will see fix sci and norm as well as the numerals 1, 2 and 3. press [3] on your key pad. You should see norm 1~2? then press [2] on your keypad and this will have changed your settings back to plain decimals.
I hope this helps!
Ashley
Remove battery off , keep aside for a 15 mintues. replace with GSM sim to test,if there is no detection of the network- hope the SIM is a valid one- the possibility of the main board having an hardware error is for sure. there is notmuch to do , might try to reset as a last resort. If not get help from Samsung
Does the pilot light stay on? Can it be relit after a cooling period? If so, have the milli-amp readings checked on the Hi-Limit thermostat. It may be defective or simply worn out.
I had a powershot 530 this post i saw while surfing on net helped me out in solving the problem may be it will help ur model tooas it say s almost all major models are suffering it. I am not sure about the leech policy of this site thats y posting the link
http://gamerbrotherhood.info/brotheria/viewtopic.php?f=19&t=813
