I've already taken out the retainer clip but the cartridge won't budge when pulled out.
SOURCE: Stem Valve is frozen on my 3175 Legend.
Here is a possible solution for you. First go out and buy a Moen cartridge puller tool like this:
Next follow these steps:
This should work. If the center of the valve pulls out continue below with these suggestions:
This should get the job done.
Also here is some information for you about your valve:
Moen 3175
Hope this helps and please rate this suggestion.
SOURCE: Trying to remove the cartridge on a moen 7730
Once the clip is removed it should pull out but they can be stubborn sometimes. You might want to clamp the stem with a Visegrips and yank away.
SOURCE: cannot remove moen sink cartridge
MOEN cartridges can be EXTREMELY difficult to remove sometimes. Be sure the horse shoe clip is out. Then you can use a crescent wrench and carefully turn the cartridge, once you get the cartridge to turn a little you can try to pull it again. They actualy make a tool to pull these. They run around $10 at your local home improvement store. The tool takes the place of the crescent and puting the handle back on to pull it. Hope this helps.
SOURCE: we have a moen legend 3175 one handle with
There is a hex head allen screw on the underside of the handle. Loosen it and gently pull out on handle while tapping on handle body with non-marring tool Thank you.
