I know what the problem is, i had the same issue right out of the box. if you take the cover off the front you will find the battery. on the bottom of the battery is a 2-sided sticky tape to hold it in place, on that tape the is probably a pulled wire. theres red blue black and white (as well as a thicker red and black that lead to the battery. find the wire that is pulled and solder it to the correct part. for me it was the white cable which controlled the top blades. the helicopter spins because both set of blades should counter rotate and if one of the motors isnt getting power from pulled cable the helicopter will spin and flip. Hope this helped. email me at
[email protected] if you need more help finding where the wires connect
Hi Brian Wolstenholme, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? What is your question?
Sorry for the confusion. I mistook ask a question for search. Basically, it either spins in circles all day or if pressure increased- climbs out of water. There is no sweet spot. Pentair told me to replace the cam kit. This did not solve the problem. Oscillator is humming along.
