SOURCE: No water collecting, unit running
the collector base under the tubes just collects water and drips it through a hole into the water bucket. there must be a loose hose(if it has one) or the base collector or bucket has a crack, as they usually are plastic. also if the unit is sitting on a very uneven floor this will happen
SOURCE: DH504EL Unit runs but does not collect water
Demumidifiers are small air comdition units with heaters. Without the change of temp they won't work. Units are often neglected and get pluged up so clean and test the air flow. The filter slowes the air speed down for the process to work properly. Finally the units run better if balanced but slightly tipped twards the drip side. You may need a bigger unit the compresser should cycle (it needs to turn off once in a while)
SOURCE: Auto shut off comes on instantly
TURN UNIT OFF.. MAKE SURE DEHUMIDIFIER HAS NOT BEEN RUN FOR AT LEAST FIFTEEN MINUTES... TAKE BUCKET OUT... HOLD IN THE BUTTON THAT THE FLOAT IN THE BUCKET PUSHES ON.. THEN TURN ON THE UNIT.. DO NOT LET GO OF THE BUTTON EVEN A LITTLE BIT IF YOU DO YOU WILL HAVE TO WAIT FIFTEEN MINUTES AND TRY AGAIN.. IF UNIT WORKS THEN YOUR FLOAT IN THE BUCKET IS THE PROBLEM...
SOURCE: humidifier runs but does not collect any water, i
humidifier runs but does not collect any water, filter is clean
SOURCE: My Goldstar Dehumidifier is not
Sounds like the fan quit....could be the board or the fan motor ...check for power at the motor...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
