LG WM-2277HW Front Load Washer Logo
A
Anonymous Posted on Jun 24, 2014
Are the pedestals interchangeable with all washers
Will the LAB2700MQ pedestal fit my washer WFW94heawo?
The LAB2700MQ will probably not fit the WFW94HEAW0. There are two pedestals listed for the WFW94HEAW0, see https://www.ajmadison.com/cgi-bin/ajmadison/WFW94HEXW.html?gclid=EAIaIQobChMI47bwhbjl5AIVCdbACh19lgPeEAAYASAAEgJOnfD_BwE . One is a 10" pedestal: XHP1000XW . Different Whirlpool washers have slightly different placements of the screw locations for connecting the washer to the pedestal. Using a pedestal that doesn't match the washer could lead the washer to be unstable and shift during the spin cycle.
I wish that I had better news for you.
Remove pedestal from washer
Those washers are heavy! They have weights in them to prevent moving when spinning. Some use bolts through the bottom of the pedestal up through the washer and others use bolts down through the washer into the pedestal. Remove the bolts and lift the washer off the pedestal. You might need to get levelling bolts for the washer or check to see if the bolts are on the bottom of the pedestal. Make sure you get help to move the machine.
Just purchased a LG 8500HSA Mega Front Load Washer Special Order! What is the Pedestal Model Number?
Please check your model number. 8500HSA does not cross to anything on LG.COM.
Universal pedestals are for sale at Sears, Home Depot, Lowers, and Best Buy. The pedestal and machine will bolt together, that is, a bolt will run upward from the pedestal into threaded bolt holes in the bottom of the washer. If you can measure the distance from bolt hole to bolt hole on the bottom of the washer, you can check to see if the universal pedestal fits before you buy it.
Several months ago I took my front loaders off the pedestals. The pedestals were kind of nice for handling the clothes but about 40% of the time I spilled either detergent, bleach, or softener because the pedestal put the drawer too high for me.
1helpful
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Attaching the pedestals to the washer/dryer
You will have to find away to remove the adjustable feet, not an easy job, I would call Sears Appliance Service
2helpful
Installing pedestal to washer
You want to level just the pedestal in the place where you will be using it so when you put it in position mounted together later it is done. Also very easy to do first. Get the pedestal level, tighten the lock nuts, put the washer on its back. Usually you remove the washer feet, take the pedestal drawer out, screw on each side, bolt the pedestal to the washer with the four screws provided. Tip pedestal and washer up, on to something that slides easily to protect floor. There usually are some type of shipping bolts that have to be removed from back of washer before using on new units. Usually four and these have to be removed.
1helpful
LG washer vibration
My wife and I originally had the same problem, and it didn't help that the washroom was a slick tile floor. First add as much weight as possible to your pedestal. We have ours full of detergents, bleach, fabric softener, etc., and have several of each so that the pedestal is completely full. When mounted on the pedestal, the washer is quite top-heavy, and the added weight in the bottom helped immensely. Second, make sure your washer is level, both the feet resting on the pedestal and the feet of the pedestal itself, and tighten the secondary rings so the feet don't vibrate out of place. Last, I purchased some thin rubber padding (approximately the thickness of leather) from Home Depot in the carpet aisle. Cut some small squares and place one under each foot of the pedestal. This gives the feet some additional "grabbing power" on slick floors.
1helpful
2answers
Attach washer to pedestal
there should be bolts that come with pedestal so you need to take your legs out of the washer now lay it on its back then bolt the pedestal up to it and if the pedestal dont have feet put the ones out of the washer on it
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
