2011-2012 Dodge Ram 1500; 2011-2012 Dodge Ram 2500; 2011 Chrysler Town ... test your fuel pump relay, and bypass a bad fuel pump relay to stay on the road. .... Mytesting/bypass device will often narrow down your problem to the TIPM ...
CarGurusNov 1, 2013 - fuel pump keeps running when key removed - 2011 ram 1500 slt quad ...fires right up but will not stay running unless I keep my foot on the gas.
CarGurusI changed the fuel pump on my 97 dodge ram 1500. Ran great for 2 days then stopped running. I can hear pump working, replaced fuel system relay, engine tur... ...Jun 24, 2012 at 03:48 PM about the 1997 Dodge Ram 1500 2 Dr ST 4WD ... The truck fires right up but will not stay running unless I keep my foot on the gas.
The combination fuel filter and fuel pressure regulator is used on all engines. It is located on the top of the fuel pump module. A separate frame mounted fuel filter is not used with any engine.
Both fuel filters (at bottom of fuel pump module and within fuel pressure regulator) are designed for extended service. They do not require normal scheduled maintenance.
