After checking power supply no 24v output only 5v can be seen
And you are sure the remote is working? You can check the remote is working, by using a digital camera (even from your phone) where you point the remote to the lens of the camera and look on the monitor of the camera is you see a flashing light on the remote when pressing a button.
Testimonial: "AT LEAST I HAVE GOT AN IDEA OF MAY BE THE PROBLEM TO THE MAIN BOARD, BUT STILL NO SOLUTION TO DO ON THE MAIN BOARD"
If you are not skilled in electronics you can't find out what voltage is not correct and why. Just check the power supply, if one or more capacitors got a "rounded" head. If there was any pressure in the capacitor it will be defect and should be replaced. You need skills to repair it yourself. Take care for high voltages so remove the power plug.
