RCA 46 46LA45RQ LCD TV Logo
R
Roshone Adams Posted on Jun 25, 2014
Televison station won't scan
No signal
juliana samson
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Jun 25, 2014
juliana samson
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
9897
Points
60
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
HiSense 55 in smart TV. Digital Antenna
This will be a main board issue, replace the board and the set will work like it's supposed to. I would take another TV and run a channel scan and be sure your antenna is picking up the channels before ordering a main
2answers
I'm trying to connect a converter box to a broksonic TV. All connections look right but the channel search is not pulling any channels. I also have an antenna connected. I need some advice, I must be...
Without more details there is only a couple of conclusions - maybe the set top box you have is faulty or incompatible in some way with either the tv or the antenna.
Incompatibility with the tv seems unlikely as presumably the on-screen menus generated by the box are displayed satisfactorily - allowing you to select a menu, scroll and select an item and then view the channel seeking process. If this is so it suggests the connection between the box and tv is good.
That rather suggests the box is faulty or the antenna is faulty or incompatible.
I have a digital tuner converter box and only get 20 channels but I want more how can I get more
Check the Internet for a list of the local air channels and compare it with the stations you receive. Then get a good outdoor antenna, mount it at the highest unobstructed possible point and hook it to the digital tuner box. Check for signal strength while turning the antenna in different directions. Choose the direction with the strongest signal and re-scan for channels. Good luck.
How do I do channel setup?
Find the "auto scan" button or setting in the settings of the TV, it will go through and find all the programs. Make sure the antenna signal is good. There may also be a setting to change the channel numbers manually to match the TV station you select. Most new TV,s will automatically program the Channel number.
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
How do find more Channels or scan with an ultra thin Antenna i only get four stations.
You are in a weak signal area and could use a good a good outdoor antenna and possibly an amplifier.
My tvs say no signal in my RV. TV comes on I adjust antenna but still no signal. Help
Are you trying to look at an analog signal? There aren't any left. If your TV doesn't have a digital tuner in it, you'll need a converter box. If it has a digital tuner, do a channel scan for digital only stations.
Did the channel scan for OTA stations, is there a way to hold these stations so I can turn antenna and rescan for more stations?
Guide to help get more channels on digital tv
spartacus-searching.com/dtv.html
Orginally there were many tv stations but the government decided to force ... Alsothese televison signals are more difficult to capture than before with analog signals. ...So that's not accurate when we are trying to find a TV transmitter. ... web page will tell you rescan for channels, thats great if you raise your antenna or have ...
How to sharpen digital TV reception via antenna
2answers
I cannot get digital to appear on television.
You will need to call your cable company to help you with that issue.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
