Take off plastic covers on the end where ISN'T motor, and then with hex key turn few times left side then few times right side (cant remeber clockwise or counerclockwise, youll figure out), leave it to run few minutes and watch if belt moves toward one of sides. If it moves to the left, your right side is tightening belt more, loose it, and vice versa.
Easiest way is to remove the back guard at the back of the belt (dark grey). I think it's #3 allen keys. There are bolts on the side, and potentially underneath.
Once removed, you will see two large bolts that connect to the back roller. Turn those with a #8 allen key (I believe). If it is because the belt is loose, I'd only do 1/4 turn on each side at a time as you don't want to tighten too much or it stretches your belt, and may also cause your lower kit to blow something.
SOURCE: change language on technogym treadmil
on technogym xt pro run 600:
press 314
display shows `password=0`
then press 2406
then press:
1 for italian
2 for deutsch
3 for english
press ENTER to save the option you made
DONE
