Question about Kyocera FS-1016 Printer
How reset error 6400
I have a problem in kyocera fs 1016 error 6400 how is reset
    New Friend:
  • 82 Answers
This machine does not support Maintenance Mode via 10871087. You have to try to separate the power pcb from the engine pwb and then reassemble tthem to see if the problem is solved. Otherwise you need to replace the power pcb. It is a common issue for this series (1016/1116MFP).
Posted on Aug 18, 2019
    Champion:
    New Friend:
  • Kyocera Expert
  • 250 Answers
1087 1087 163 print key
Posted on Aug 14, 2019
5 Suggested Answers
6ya staff
SOURCE:
Nikolay Boychev
  • 525 Answers
SOURCE: tengo una kyocera 1016 sale
Code: 6400
Contents: Zero cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Causes:
- Defective the power source PWB.
- Defective the engine/high voltage PWB.
Posted on Feb 21, 2011
Nikolay Boychev
  • 525 Answers
SOURCE: Kyocera fs 1016 mpf printer
Code: 6400
input within 3 s.
Causes:
aviral_srms
Aviral Saxena
  • 1216 Answers
SOURCE: kyocera fs 1016 engine panic
Disassemble and look the fan side of the fuser, there you will see that the wires pass through a **** that is more of a cover remove it and there's the can on that side is where will the current regulator and the high card that connects to the source card,
Well it happened to me this issue, I found the card and it was high toner developing unit that was discarding, in addition to the seal of the doctor blade was worn out, another issue I found was current leakage, what I did was make the can land top with more pressure to the high card, in addition to not fall toner worn by the seal tape to tape the holes in the chassis, after that I have not been flawed
Posted on Jul 14, 2011
Mike
  • 167 Answers
SOURCE: KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Posted on Dec 13, 2011
1116 error 6400
Remove and reinsert the two connectors of the fuser unit. If not, then remove and reinsert all the connectors from the engine pwb and the power pcb.
Jun 03, 2014 | Kyocera FS-1016 Printer
Service call 6400
Buenos dias no se que hacer cada que doy a imprimir me sale error call 6400 llame servicio tecnico, a que se debe y que puedo hacer
Oct 04, 2013 | Kyocera FS-1016 Printer
Error call service 6400
Shows as a fuser error (zero cross signal error) but we see this being the power supply and/or bad power to the unit. Check your power outlet (it should be on a separate or dedicated plug with no other devices). Remove and re-seat the drum unit and DV unit. Could be the fuser but if it comes back its the power supply
Sep 30, 2013 | Kyocera FS-1016 Printer
Service call 6400
HOW DO I RESET ERROR C6400 FOR OLIVETTU D-COPIA 18MF
Aug 21, 2013 | Kyocera FS-1016 Printer
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
Error de llamada 7980 en kyocera fs 1016 mfp
Mar 01, 2011 | Office Equipment & Supplies
Tengo una kyocera 1016 sale error call 6400 como elimino es problema por que nesecito solucion gracias
Code: 6400
input within 3 s.
Causes:
Feb 09, 2011 | Kyocera FS-1016 Printer
Kyocera fs 1016 mpf printer error service call 6400
Code: 6400
input within 3 s.
Causes:
Dec 15, 2010 | Kyocera FS-1016 Printer
Kyocera FS-1016 Printer Logo
536 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
