Hi, I connect H350 via USB connection to my computer to charge. After connecting blue light will hover faintly for a few seconds, then the light will become full strength; this however will only last for less than 1 minute before turning itself off. Battery was completely empty before this. Pressing and holding power button does nothing to turn the unit on, or make any changes to light pattern. Please help.
SOURCE: connecting bluetooth headset
You have to go through a process to pair the devices.
Firstly:
Make sure bluetooth is turned on on your laptop (varies for each model)
Make sure the headset is fully charged.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Then goto the bluetooth control panel and select "Look for Devices" or similar. Wait until the device has been found and when it asks for a passkey, enter 0000 and press okay.
see some more info at: http://tinyurl.com/2bz7hc
SOURCE: H700 automatically disconnects though fully charged
I had the same problem. It does seem to be related to the battery. The solution--in my case--was to recharge the headset until the light turned green again and then flip it open and it hooked up again.
SOURCE: Light always ON!!!
hold the button and wait till the light blinks twice and it will turn off
SOURCE: i need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
SOURCE: Connecting Motorola H350 to PS3
1. SWITCH ON THE POWERBUTTON BTHS AND PRESS THE PUSHBUTTON FOR A FEW SECONDS UNTIL THE
LIGHT STOPS BLINKING.
NOW YOU CAN SEARCH FOR THE BTHS. AFTER SEARCHING PAIR IT ,PASSSWORD IS 0000.
Add; The unit will pair with the phone in the short time that the blue light is responding but after the same time period *(of about 1 minute) the blue light will then cease to flash *(and in my opinion stops charging)
