SOURCE: what does F7 mean on a whirlpool 6th sense washing
F7 in whirlpools means "Clean the filter”.
The following troubleshooting steps would help fix it. Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a program this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filters clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
Thank you for contacting www.Fixya.com
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Thank you for writing to fix ya.
Best regards Richard
SOURCE: whirlpool 6th sense front load washing machine
I have the same problem. Stops randomly during the cycle and turning off the power for a second re-starts it.
I think it is one of the sensors is faulty - for example the sensor that detects if the load is un-balanced, or if the machine has enough water.
Seems to be a common poblem for these machines.
I'm going to try to find which one later today.
SOURCE: Error code F13 is showing
Check
mechanical linkage from dispenser motor to the top of
the dispenser.
Check
Wire Harness connections to the dispenser motor and Central
Control Unit (CCU)
Check
Dispenser Motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: My Whirlpool Washing Machine 6th Sense 10kg
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
