Question about Kyocera FS-1028MFP Mono Multifunction Laser Printer
What is the default Login Password used to enter the System Menu on the FS-1135MFP
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kyocera Expert
  • 210 Answers
Usally the speed of the machine with two zeros or try Admin or Admin00
Posted on Aug 06, 2014
6ya staff
SOURCE:
Tip
How to Reset Windows Password with Default Admin Password?
The Windows operating system allows you to assign a password to each user account. This provides privacy to different users on one computer. Each user is allowed to set up his own environment and settings to maintain personal files. The difficultly comes when a computer is not functioning correctly and needs to be put into safe mode, but a password is not available. Creating a disc on Windows permits you to <a href="http://www.passwordunlocker.com/knowledge/6-windows-password-recovery-solutions.html">reset Windows password</a>, get access to your locked computer and replace the forgotten or lost password. <br /> Let us discuss the method of <a href="http://www.passwordunlocker.com/knowledge/windows-password-recovery-tool.html">Windows password recovery</a>, if you have access to any of the account with administrator rights or you have not assigned a password to the account with username administrator. Administrator is the default account created in the Windows when it is installed. This has a blank password by default.<br /> start your system to reset the Windows login password. If classic login dialog box appears, write the user with administrator privilege if you know any of them, type its password and press enter to login. Otherwise, type administrator in place for the username and press Enter. If you are successful to login, open the Start menu and click Control Panel to open it. Open the user account and change the password of the desired account. Restart you system to login your account with the changed password. <br /> If your logon screen is Windows XP style, administrator user will not be shown on the logon screen. You have to boot in Safe Mode. Restart your system and press F8 key to display the boot options. Choose the Safe Mode option and press enter to boot. Windows skips loading many drivers. Administrator account is shown in the logon screen. Click it to login. After the Windows desktop is shown, open the Control Panel from the Start menu. Change the password of your account.<br /> Well, still can not successfully solve your Windows password recovery trouble? You'd better take use of a third party software. As is known that <b><a href="http://www.passwordunlocker.com/windows-password-recovery.html"> Windows Password Unlocker</a></b> is considered to be a professional and appreciated Windows password recovery tool with 100% recovery guarantee and friendly interface. Furthermore, this program can keep all your data and files in security.<br />
on Jun 29, 2011 | Computers & Internet
How do i change from military time to regular time on kyocera fs 3640
The Date/Time settings in FS-3640MFP is in the system menu. Press the system menu/counter key, find (inside the menu) the System and then the Date/Time and change whatever you want. The login usernane and login password is 4000.
Jul 16, 2014 | Kyocera FS Office Equipment & Supplies
How to reset a forgotten admin password on a Xeroc DC252
DocuColor 242 252 260 Online Support Solution Modify the Administrator...
Solution : Modify the Administrator Password From the Control Panel
  1. Press the small round [Log In / Out] button located on the left side of the Control Panel. The System Administrator Login screen will be displayed.
  2. Enter the System Administrator Login ID using the numeric keypad on the Control Panel, and then select the [Confirm] button on the Touch Screen. The System Administrator Menu screen will be displayed.
    NOTE:The System Administrator Login ID and UserID is "11111" by default. If an error is made, press the [Clear (C)] button and re-enter the ID. To cancel the operation, select [Cancel]. If the administrator has a problem with changing or has forgotten the ID, a service call must be placed.
  3. Select the [System Settings] button twice. The System Settings screen will be displayed.
  4. Select the [Change System Admin Login ID] button.
  5. Enter in the new password.
  6. Select the [Save] button to save the setting.
  7. Select the [Close] button several times, and then select the [Exit] button to exit.
Apr 03, 2014 | Xerox Office Equipment & Supplies
FS-1135MFP getting error 2101 when scaning doqument
fs_1135mfp_getting_error_3101_when#solution-heading
Jan 12, 2013 | Kyocera FS-1135MFP
How do i change the number of rings for xerox workcenter 123 to pick up for receiving fax
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings] twice. The System Settings screen will be displayed.
  6. Select [Fax Mode Settings]. The Fax Mode Settings screen will be displayed.
  7. Select [Fax Defaults]. The Fax Defaults screen will be displayed
You wll then see locations to set the amount of rings to answer, ECM mode etc.
Jul 23, 2010 | Xerox WorkCentre M128 Copier
Access authorization code
I think this is the one you want to change. If not let me know please.
  5. Select [System Settings]. The System Settings screen will be displayed.
  6. Select [System Administrator Settings]. The System Administrator Settings screen will be displayed.
  7. Select [System Administrator Login ID]. The System Administrator Login ID screen will be displayed.
  8. Select [On].
  9. Enter a new System Administrator userID in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  10. Select [Next] and re-enter the System Administrator userID in the field provided.
  11. Select [Save] to save the changes.
  12. Select [System Administrator Password]. The System Administrator Password screen will be displayed.
  13. Enter a new System Administrator password in the field provided using the numeric keypad, or select [Keyboard] to use the Touch Screen keyboard.
  14. Select [Next] and re-enter the System Administrator password in the field provided.
  15. Select [Save] to save the password.
  16. Select [Close] three times.
  17. Select [Exit].
    NOTE: Make note of the new System Administrator userID and password. If the new System Administrator userID and password are forgotten, a service call must be placed
Jan 29, 2009 | Xerox CopyCentre C123 Copier
I need to change the access code as some non authorized people are using my photocopier. How can I do that?
I am answering this twice since it appeared twice, If this isnt the code you want to change let me know. I believe this is the one you are asking.
  8. Select [On].
  17. Select [Exit].
Need to establish PIN/Code for machine - help xerox c123
The following information describes how to register userIDs and usernames, login names, and passwords for authenticating accesses attempted through the network for scanning services, and impose restrictions on the maximum number of pages to be copied or scanned. Up to 500 user accounts can be registered.
NOTE: You must be a System Administrator to perform this solution.
  6. Select [Login / Auditron Administration]. The Login Setup / Auditron Administration screen will be displayed.
  7. Select [Create / Check User Accounts]. The Create / Check User Accounts screen will be displayed.
  8. Select a user account number or use the numeric keypad to enter a user account number in the Go to (001-500) field.
  9. Select [Create / Delete]. The User Account screen will be displayed.
  10. Enter a userID using the keypad on the Touch Screen, and then select [Save]. The Create / Delete screen will be displayed.
  11. Select from the following options:
    • UserID: Allows a userID to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • User Name: Allows a username to be entered using the keyboard on the Touch Screen. Up to 32 alphanumeric characters can be entered including spaces.
    • Password: Allows a password to be entered using the keyboard on the Touch Screen. 4 to 12 alphanumeric characters can be entered. The Password button is also displayed if a password was selected on the Login Setup / Auditron Mode screen.
    • Remote Login Settings: The following settings can be modified on this screen:
      • Login Name - Allows a login name to be programmed that needs to be entered when the machine is accessed through the network.
      • Password - Allows a password to be programmed that needs to be entered when the machine is accessed through the network.
    • Account Limit: Select [Copy Service] or [Scan Service], and then select [Account Limit]. Using the numeric keypad on the Control Panel, specify and restrict the maximum number of pages to be copied or scanned for the account. The maximum number can be entered within the range of 1-9,999,999 pages.
    • Reset Total Impressions: Deletes all data tracked for the selected account.
    • Reset Account: Clears all settings and data for the selected account.
  12. Select [Save].
  13. Select [Close] three times.
  14. Select [Exit].
Jan 08, 2009 | Xerox CopyCentre C123 Copier
How do I enter the User ID codes for a Xerox CopyCentre 275?
The Tools menu is used to set up machine parameters. The menu is protected by a system password, referred to as the System Administrator password. The default system password is 1111.
NOTE: If the System Administrator password has been changed or forgotten, contact Support for additional assistance.
  1. Press the [Access] or [Access A] button on the Control Panel to enter the Tools Mode. The Login screen will be displayed.
  2. Enter your password using the numeric keypad on the Control Panel, and then select [Enter] on the Touch Screen. The Pathway Options screen will be displayed.
    NOTE: The default password is 1111. The password will be displayed as an asterisk (*). If you make a mistake, press the [Clear (C)] button on the Control Panel and re-enter the password. To cancel the operation, press the [Cancel] button. If you are experiencing problems with your password or have forgotten your password, contact your administrator.
Sep 09, 2008 | Xerox Office Equipment & Supplies
Kyocera FS-1028MFP Mono Multifunction Laser Printer Logo
198 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
