Question about Chromo Inc Chromo AAAAAAAA White 4gb 7" Android 4.0 Touch Capacitive Screen 1.2ghz 512 RAM Mid Tablet Pc Wifi 3g Camera Tr-a13 - Bonus USB 2.0 to Micro USB Adapter
I have a Chromo 7" tablet, IOS wont start up.
The tablet will power up and appears to start but when it gets to the screen that reads Android that's where it stops and just flashes Android forever , never loading my homepage, can you help?
    Genius:
  • 2,432 Answers
Have you tried to press the reset button in back of your tablet.
Posted on Jun 26, 2014
6ya staff
SOURCE:
Can you do a screenshot on the Trio Stealth G2 9.7 Tablet?
This should work on any Android 4.0 and newer tablet.
To take a screenshot on your device, press the Volume Down and Power keys at the same time.
The screen will flash, you'll hear a sound, and you'll see a framed image appear and fade into the notification bar. The "Saving screenshot" notification will appear.
May 10, 2015 | Mach Speed Trio Stealth G2 Tablet -...
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
My android tablet will not start it flashes the battery but will not start
is it a pipo m8 model ? not getting a listing for this model, if you have it on charge does it still do the same thing, blank screen could be the sd card inside has fell out. this is on some models has an 8gb - 32gb sd card inside. other models it can be a read error of may ram. if it has volume controls on the side hold down the power and volume down at same time and then lift fingers off and see if the android software comes up, can take a few times to get it up takes a bit of practice to get it up but does not work on some. when the menu comes up you will have a list of things you can do choose the one you want to do reset system last know good etc and see if that fixes it. failing that you will need to open the tablet up and remove the battery and check the sd card if it has one inside.
Apr 03, 2014 | Tablets & eReaders
How to reset tablets
Do a hard reset, press and hold the +vol button, then the power button, wait about 20 seconds both buttons held till the start android screen appears. Hope that helps
Mar 24, 2014 | Proscan 7-Inch Android Internet Tablet,...
PC802 Google Android 2.3 8 inch Flash 10.3 External 3G Resistive Screen Tablet PC
Only the applications that are compatible with each Android system should appear in the Google Play Store pages. If you are installing from your PC, it will inform you of any compatibility. If you are installing apps from 'unknown sources' you will run into trouble and, will damage your system permanently.
May 19, 2013 | Easy PC802 Google Android 2.3 8 inch Flash...
Chromo Inc Chromo AAAAAAAA White 4gb 7" Android 4.0 Touch Capacitive Screen 1.2ghz 512 RAM Mid Tablet Pc Wifi 3g Camera Tr-a13 - Bonus USB 2.0 to Micro USB Adapter Logo
508 people viewed this question
Top Chromo Inc Tablets & eReaders Experts
langhi
 Mike M
Mike M
 Mikey
Mikey
Are you a Chromo Inc Tablet and eReader Expert? Answer questions, earn points and help others
