Said this, I don't mean to "panic" you but if you can't find this "restet" function, your refrigerator suffered a surge effect and might have some electronic cricuir damaged; in best case, some internal security fuse, typical as result of power outage, when power returns.
If you can't find that "reset" call repair service.
By the way, get a surge protector for your refrigerator as soon as possible. See some typica protectors at Amazon, but you can buy one at your local home depot or outlet store.
Please visit the site HERE it.You will find a solution to your problem.
I would also suggest holding the power button on the Wii Remote itself to
turn it on, or unplug your Wii Console's power cable and audio/video
cable for 90 seconds. Then plug power in first, then AV cable.
Locate the switch next to the water filter status light. Press the light switch five times in 10 seconds or less. Wait for the status light to change from red to green.
Do you have good power that the outlet. I have seen many issues at RV parks of not having sustained power or one leg of the breaker going bad causing loss of power. If you do have good power coming into the surge protector but not out. Then go through the reset procedures for the surge protector. If it will not reset, then the surge protector has failed and will need to be replaced. If power is coming through then check the main breakers in the coach for possible failure. Breakers can trip but still look as if they are properly set. Turn them completely off then back on to reset.
Have you tried plugging it in without the surge protector? I would wager that either a) the surge protector needs to be reset/turned on and off depending on the model or b) either your TV and/or surge protector have been damaged by the power surge.
Try plugging the TV straight into the outlet and see if that helps.
Dear Sir: Thank you by your problem, I will help you inmediately.
Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor that is UL 1449 listed as a transient voltage surge suppressor (TVSS). The surge suppressor must have a UL suppressed voltage rating of 400 volts or less and a minimum surge dissipation of 450 joules. The surge suppressor must be electrically rated for 120 volts AC and 15 amps. Important: The treadmill is not compatible with GFCI-equipped outlets.
2)After the power cord has been plugged in, make sure that the key is fully inserted into the console.
3)Check the circuit breaker located on the treadmill near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch back in.
4)Check the on/off switch located on the treadmill near the power cord. The switch must be in the on position.
I hope you resolve this. Otherwise, try to reach me. Inmediately.
Please check if your surge protector is working properly now. There is possibility that the surge protector is blown off due to high voltage surge.
Check if your surge protector has a reset switch which some of the surge protectors have.
If the problem still persists then you have to call the technician to replace the safety fuse which is inside the TV. The cost will not be much.
I will personally recommend that you change your TV as it has outlived its life being 10 yrs old.
most surge protectors have some sort of on/off switch and a reset button. If there was a surge then you would need to pres the reset button to get the surge protector to function again. If there was no surge then try using the on/off switch on the surge protector to see if that helps. Also try simply unplugging the power cord from the back of the desktop while the computer is turned off. This will sometime also help.
