SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
SOURCE: error code C0F37 on Kyocera mita KM-C1530
This code is not documented, the firmware must be reloaded and a service tech can only do it ...
SOURCE: Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
SOURCE: I have a Kyocera Mita 1635 Copier and it's giving blank copies
Ensure that you have cleaned the main and transfer corona's as shown by the instruction leaflet that comes in the box of toner.Also ensure that the large left cover is correctly closed.It is possible that your copy paper is very damp so try changing it for fresh paper or put 20 sheets in the microwave for around 15 seconds to remove the excess moisture.Also are you using genuine toner?
SOURCE: i am geting an error code of c3100 call for
Your scanner cable broken or twisted inside. You need to call local representative for further action.
