When I use the menu to set the picture quality and turn the dial to select raw, the options for jpeg move instead of raw. what can i do to choose raw and jpeg?
Please check the size of the memory card, it may not allow you to select raw with a small sized card, if this does not work , clear all camera setting, and clear all custom settings, check and re-load firm ware
In order to select RAW mode, first check if your camera is in either Manual(M)/(A)/(AV)/(Ev) modes. Then go to setting-picture format-RAW/RAW+Basic.
In order to edit the RAW picture, you need to update the RAW version if you are using Adobe Photoshop for editing your pictures.
Thank you!
Regards,
Pratish Shrestha (pratis010)
SOURCE: Choosing to shoot Raw images
On my 400d, you need to be in one of the manual modes (P, Tv, Av, M or A-DEP) before being able to select RAW.
HTH,
Simon.
SOURCE: only jpeg on raw+jpeg
This is strange. Is the camera putting the Raw (CR2) files in a different directory somewhere?
Try reading the disk in a reader rather than plugging the camera into the computer, and explore the disk.
If it's really not recording RAWs then I'd call Canon... They're usually very good indeed with photography.
Steve
www.yourhandinmine.co.uk
