Something inside the bottom drawer has wedged the drawer so I cannot pull drawer out-can you help me
SOURCE: Rust On Bottom Of Chest Freezer
id sand it paint it with white rustolm and go from there and no it couldn't there is a layer of foam between the bottom of the outside and in side
SOURCE: Drain freezes and glacier forms inside bottom
hi thanks for the question the drain hose leading from the freezer is clogged up remove the ice from the bottom pull fridge from wall find small drain tube clean the tube now it will drain into tray vacuum out while your there thanks the appliance doc
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
SOURCE: I have a small (I'm guessing about 5 cu ft)
I would use a hairdryer to defrost the door secton with the other part closed off or covered.
