How i can change OPC drum kyocera 3920DN printer
SOURCE: Kyocera 1810 drum replacement
If you have some mechanical skills and a steady hand you can change the drum. However it worth the money to pay a "pro"to do it. Also you may want to replace the cleaning blade too.
1. Open the front cover - where the toner is.
2. Remove the black cover - 2 screws
3. Remove a little stopper at the bottom of the drum unit + 1 screw
4. Disconnect the drum unit cable.
5. Take off 2 screws which secure the Drum Unit.
6. On top of the Drum unit you should see 2 white plastic stoppers - front and back side ends - You have to push them inside to keep the cleanng blade away from the drum.
7. Remove the MCH assembley - 1 screw.
8. Remove the front separation claws + plate - 2 screws.
9. Remove the Drum Shaft
10. Replace the Drum
There are few details about how to manipulate a Drum - Do not touch the surface, do not expose it to intense light...
8.
SOURCE: change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
