Is this an electric unit? If so please this can be easy to repair. If this is a gas unit I need to know what model number you have. Please provide more information. I look forward to resolving your issue.
Steven
Totally Tankelss LLC
Reset Button.....be nice if you gave us a brand/model to go with.
If you mean the small GFCI inside the heater, you'll need to get a Tech Service Call and call Mfrs Tech Support as something is short to ground. This can't be done remotely as you have to track currents and voltages and resistances with a multimeter.
Tankless usually draw less than 2A even when fully on so doubtful you're overloading a general house circuit.
Might even be the small interior GFCI that's bad. That's why you need Tech Support.
SOURCE: reset keeps triping
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXTechSupport/Troubleshoot/tabid/563/Default.aspx
click on this link and it has the troubleshooting in strucktions for the unit . hopt that it helps you out.
SOURCE: water wizard 10P pilot light keeps going out
If the thermocoupler is defective the gas to everything is shut off. The coupler is the bulb that sits ib the pilot flame If it doesn't heat up it will sense no pilot and shut the gas off. They don't cost much and are easy to change. Good Luck, Ned
SOURCE: Our hot water heater keeps needing to be reset.
overheat stat or fan
Testimonial: "That's what we thought, too! Thanks for your advice."
SOURCE: my ariston electric hot water heater keeps
Tripping off at the water heater or at the breaker box?
