We recently moved offices and my printer is now giving me problems. It will print 1 or 2 good pages (different documents) and then goes to printing blank pages for the next few documents. Feeds paper through and acts/sounds like it's printing but the pages are blank. I've uninstalled & reinstalled the printer drive, disconnected everything and reconnected, several restarts and shut offs. I cannot find any rhyme or reason to when it decides to quit working. The ink cartridges did not need replacing. And as I said, I will get a good page once in a while. Any thoughts on what to check?
Printer Printing blank page issue can be occurred when you have low or dried ink cartridge, blocked nozzles, dirty print head and ink cartridge installed improperly. Follow the troubleshooting steps to fix printer printing blank pages:
·Restart the printer
·Check printer ink cartridge
·Clean the printer print head
·Update the printer drivers
Follow more steps to fix the Printer printing blank pages issues
SOURCE: Deskjet 3845 not printing properly
it needs a proper service as the moving parts are not moving freely .. or maybe when installing the cartridge you have damagaed one of the sensors .. it can be one of both
SOURCE: HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
SOURCE: HP 7350 printing goes through the motions but nothing
I had the same problem and couldn't figure it out until I found this on the web - I changed the DEP setting and now I can print just fine. Hope this helps you too!!
Julia
Source:
http://www.tech−archive.net/Archive/WinXP/microsoft.public.windowsxp.print_fax/2006−06/msg00081.html
· From: Shawn D <ShawnD@xxxxxxxxxxxxxxxxxxxxxxxxx>
· Date: Sat, 10 Jun 2006 07:40:01 −0700
I just figured out my issue. It had to do with DEP − Data Execution
Prevention. I had remembered that I was fooling around with this a couple
weeks ago and had changed it to "Turn on DEP for all programs and services
except those I select" in which I had Windows Explorer checked. I just got
done selecting the original which states "Turn on DEP for essential Windows
programs and services only", rebooted, and now I can print again to my hp
7350 printer.
The DEP can be found under control panel−>system−>Advanced Tab−>Performance
Settings−>Data Execution Prevention Tab
Hope this helps.
SOURCE: Printer feeds blank pages.
often in the Printer properties, there is a tickbox, to feed a blank sheet between print jobs. this is to assist in keeping print jobs seperated on busy printers.
Here is the way to change the setting on a single print job:
Making the change a permanent thing For All print Jobs on this printer:
