Kenmore 24032\24036 Top Load Washer Logo
A
Anonymous Posted on Jun 27, 2014
Need to calibrate kenmore washer 11021302012 - Kenmore 24032\24036 Top Load Washer
2answers
Kenmore elite washer he5t f15 error code
Give this a try to see if it'll reset...disconect power to it for 30 seconds while no power press power button for 10 seconds then press the start/pause button for 10 seconds. Plug in or turn breaker back on and see if it reset.
Best to You
1helpful
Why does my brand new Kenmore gearbox whine on different cycle settings?
Whining is actually indicative of it working slickly. It should quieten down, but no problem if it doesn't.
1helpful
Kenmore series 500 washer wont shut off once its done unless you push the start stop button and lift the lid it just starts over again. I already did the calibrate mode with no success.
I don't have a model number but it sounds like the unit is in the life test mode. I'm assuming that since you have tried to calibrate it, you know how to get into the test mode. PUT THE UNIT INTO TEST MODE, THEN TURN 13 CLICKS TO THE RIGHT SO THAT WASH, RINSE AND CYCLE COMPLETE OR END OF CYCLE IS LIT. PRESS START. ALL LIGHTS SHOULD GO OUT AND NOW YOU ARE OUT OF THE LIFE TEST MODE. THIS IS USED AT THE FACTORY FOR EXTENDED TESTING AT FACTORY WITHOUT HAVE TO RESTART WASHER
I have a Kenmore vmw washer (made by whirlpool) mod 11021302012. It empties but does not spin.I cannot turn the drum from the bottom or the top. On the belt guard, there are greasy rubber shavings.
Pull the top off the cabinet, check and make sure there is nothing stuck between the drum and the tank. If there is nothing then you need to pull the drum and check the bearings and the gear case.
4helpful
2answers
Kenmore washer model #21302 lock on light is flashing, will not start
Kenmore top load washer 21302, the sensor light is on and the lid lock light is on with a clicking noise. What could be wrong with it and how do I fix it?
Wtw 4950 wont start
you need to get into diagnostic mode and check the error codes. This washer will give you couple of error codes but the first one is the latest. To check error codes
How to Read Vertical Modular Washer VMW Error Code Display
Calibrate/reset error
How to Calibrate Top Load Washer
After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
1helpful
2answers
Kenmore Oasis Ld code
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
Kenmore Series 90 Washer dial isn't calibrated correctly
push the knob to off and turn knob only to you left...off is in..always unplug unit first
2answers
Kenmore 24032 washer
when you reassembled the case you have pinched the clear tube that goes to the water pressure switch aginst the case and back panel, lift up the console remove the case clips and make sure that the pressure hose comes up through the curve part in the case if pinched off the pressure switch will not satisfy
let me know if you need any more help
Alexander
vince
