SOURCE: The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
SOURCE: Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
Thank you for your post, friend!
From what you have described your Frigidaire dryer beeps continuously when not in use. This could be an issue with your wiring harness or control panel. I would recommend performing a power reset on your dryer and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not resolve your issue I would recommend contacting a technician. The technician will have the appropriate tools needed for proper diagnosis and repair. Hopefully this information is helpful. -Matt
