SOURCE: Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
SOURCE: I cannot print on my windows 7 PC connected to a
The Driver is available online for windwos 7, go online to www.copystar.com , choose download and then the machine model number and then the printdrivers. Choose the Kx driver for windows 7.
This will fix your problem.
thanks for using Fixya
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
SOURCE: I have Windows 7 in
download the latest version of driver fro win 7.run the software and then connnect the machine to laptop when it asks to.thats it
