Whirlpool ED2FHEXN Side by Side Refrigerator Logo
A
Anonymous Posted on Jun 28, 2014
Lms - meaning - Whirlpool ED2FHEXN Side by Side Refrigerator
2helpful
Need a replacement battery for Dl1/3N duracell 3v
Here is a list of equialent batteries that are calimed to be able to replace the one you specify.
Equivalent Batteries Cross Reference: Duracell DL-1/3N, 3N, Ray-O-Vac 867, 2L76, Energizer 2L76BP, 2L76-BP, CR1108, IEC CR11108, CR1-3N, DL1-3N, Dantona Comp 15, Duracell DL1/3N, NL1/3N, Energizer LR1/3N, Eveready 2L76, L76BP, I.E.C. 3V CR1/3N, CR1/3N, CR11108, Innotek M041101, Kodak K58L, National HM-N, NR-52, NEDA 5008L, 5008LC, Nikon F-1, Sony CR1/3N, Varta CR1/3N, LaserMax LMS-1/3N, LaserMax LMS-1/3N 5PK, LaserMax LMS-UNI-G
2answers
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
1helpful
My LMS-522C keeps losing it's position on the GPS.
I'd suggest calling Lowrance.. Those guys are very helpful with step by step support... I just purchased a used boat with a 525c df on it and been troubleshooting some problems with it. Central time zone and best to call right when they open or turn on the phones at 8:15.
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Lowrance lms 330
have a lowrance lms-330c the depth no. keep changing from hi no. to low no. can not stop it,,, will not show true depth,,, can you help?,,,where can i send it to get it fix?
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
