Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
A
Anonymous Posted on Jun 28, 2014
How to route the drive bale on a husqvanara mdel18542
Is there a plate between back end attached to axle to aid bale discharge on Welger 435 master baler
It is possible that the Welger 435 Master baler may have a plate located between the back end and the axle to aid in the discharge of bales. This plate, which is sometimes called a bale ramp or a bale slide, is designed to allow bales to be more easily loaded onto a trailer or other transport vehicle by providing a sloping surface for the bales to roll down.
To confirm if your Welger 435 Master baler has a bale ramp or slide, you can check the owner's manual or consult the manufacturer. You can also inspect the baler itself to see if there is a plate or ramp located between the back end and the axle. If you are unable to locate the bale ramp or if you are unsure if your baler is equipped with one, it is recommended to consult a mechanic or the manufacturer for further assistance.
New Holland 72 bale thrower will not increase or decrease speed on belts.
From what I've discovered there's a lot of issues a hand---I found a site that has different issues with model---variety of various items contribute to the same problem----you'll have to find you particular issue--there a list of items that may apply to you situation that you'll have to check out---GL
https://www.google.com/search?q=New+Holland+72+bale+thrower&rlz=1C1NHXL_enUS713US714&oq=New+Holland+72+bale+thrower&aqs=chrome..69i57j0l3.2071j0j9&sourceid=chrome&ie=UTF-8#q=control+speed+of+belt+New+Holland+72+bale+thrower
How do you route the baling wire?
Sorry about the previous answer. Your question shows up as Question about Riding Mowers & Garden Tractors
How do you route the bailing wire?
There is no mention of what you were asking the question about.
At the link below you can download the user manual for your baler.
John Deere Ag New Equipment Technical Publications Publications Search
Aug 28, 2014 • Garden
Around and around the broken parts.
How do I get a tighter bale from a 335 baler
www.deere.com/...support/...support/product_support...
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
