The no start on the first try could be low fuel pressure. The check valve in the pump may be letting fuel drain back into the tank, or the pump relay may be bad. The pump gets power from the relay when you turn the key on, then from the oil pressure switch once the engine starts. How do you get the interior lights to go off ?
Led 1= Prewash / 3hr Led 2= Wash / 6hr Led 3= Rinses / 9 hr Led 4= Drying / 12hr
LED. illuminated 1 = Overflow ( water in base ) tip machine back. does water come out? if so you have a leak, possibly from bottom spray arm nut or loose salt pot. see if they are loose. if not, remove the base, put dishwasher on a block of wood, shine torch underneath to see where the leak is.
1+2 = Pump timeout, or Software recognition error ( timer not programmed, wrong keypad)
1+3 = Circulation pump not working
2+3 = Not filling
2+4 = Heating circuit not working
2 = Solenoid valve 'broken'
3 = Thermistor (NTC) cicuit not working
4 = Temp not reached whilst heating ( poss NTC detached from casing). remove door panel. ntc is attatched to the rear of dispenser, a little white thing with 2 black wires on it. refit to the clip on the dispenser.
It is usually necessary to 'reset' the machine after a fault code has been displayed.Resetting. Switch dishwasher OFF, rotate the selector switch to STOP/CHANGE and switch on, after a few seconds the LEDS will go out enabling a new programme to be selected
You said when if the game starts the controller goes off.try holding the sync button on the wii console for 15-20 seconds then resync all controllers.If it doesn't work try this:Start the donkey kong game then press the home button then go to the wii remote settings it has an icon of a remote then after you enter it find the reconnect then press 1-2 simultaneously to select who is the first player.If it doesn't work try resynchronizing it as the first controller.Hope this helps.
check the fuel filter it sounds like it's pluged and causing too much back presure this is causing an over load in the fuel pump causing it to stop working or to presure lock
Check the water supplies at the back, if the valve is opening, and the
water is getting into the machine, it can be a faulty water level
switch, or membrane sensor, depending on the model.
A faulty or clogged inlet valve can also close few seconds from opening the valve, usually becausu of a faulty solenoid.
If valve and water level switch are ok, then this is a faulty control.
