Question about Apple iPad 16 GB 3G Tablet PC
What kind of cable do I need to hook up my ipad to tv
Ipad 3 32 g
Ipad to Sony smart TV using Ipad charging call what is the proceedure?
The charging cable won't work. You need the optional a/v cable.
Oct 13, 2016 | Sony Tablets & eReaders
Ipad to Smart tv how to connect
Yes that is a USB and should do the trick.
Oct 13, 2016 | Apple iPad Mini
How do you connect ipad to computer
To help you connect your ipad to the computer, please follow the step-by-step instructions given below:
- Turn both the computer and iPad ON before connecting.
- Plug the iPad's docking port into the appropriate end of the dock connector-to-USB cable.
- Plug the USB end of the iPad's dock connector-to-USB cable into an open USB port on your desktop. If iTunes doesn't open automatically, open the program to sync files and apps between the devices.
- Do not disconnect while the iPad is syncing or the sync won't complete.
- Remove either end of the cable to disconnect your iPad from the PC.
- After the first connection, you may choose to connect the two via Wi-Fi so you don't need to use the cable.
- Using iTunes, you can sync your audio, video, photos, apps and documents. This lets you transfer important files and apps you use for your business between your iPad and computer.
GuruAid.com
May 15, 2016 | Tablets & eReaders
IPad to element hdmi monitor
Depending on which kind of iPad you have, you will need a Lightning to HDMI adapter (http://store.apple.com/us/product/MD826ZM/A/lightning-digital-av-adapter?fnode=3a) for a newer iPad with a Lightning connector or a 30-pin to HDMI adapter (http://store.apple.com/us/product/MD098ZM/A/apple-digital-av-adapter) for older iPads. After that, just plug a regular HDMI cable into the TV and adapter.
Oct 01, 2014 | Apple iPad 64 GB WiFi
Sync iphone and ipad
Hey friend. What kind of files do you want to sync between iPhone and iPad? Let's say, if you're planning to sync music from iPhone to iPad, you can simply rely on iTunes.
Please note that if you have hundreds of thousands of songs in iTunes Music Library, you'd better create a separate playlist for the songs you want to transfer. Then you can choose the playlist when you sync music to iPad with iTunes. The following guidance will show you how to transfer songs from iPhone to iPad with iTunes.
1. Transfer Purchased songs from iPhone to iTunes Music Library.
Sync Music
2. Connect iPad to computer with USB cable.
3. Click the iPad icon and choose Music.
4. Check Sync Music, and choose the iPhone music playlist.
5. Click Sync at the right bottom.
3 Ways to Transfer Music from iPhone to iPad
Aug 17, 2014 | Tablets & eReaders
Is this model capable of running netflix through it?
It depends on the tablet which cable you need. Samsung has a series of cables for their devices and so does the ipad
Jun 11, 2014 | Tablets & eReaders
How do you tranfer photos from I Pad to a PC?
There are a few ways to accomplish this task, first you could just email yourself the pictures if your tablet is hooked up to a wifi network. Second is to hook your sync cable to it and then your computer. IF you are using a PC then simply plug in the sync cable to the ipad and the other into the USB port on your computer. The computer should be attempting to install Apple drivers in order to be able to see the iPad as a storage device. Once it completes it's installation you go to my computer and you should see all the drives available to access. You are looking for one called Apple iPad click on that, then go to internal storage/DCIM/ there maybe a folder or two your pictures that are on your ipad are stored within the DCIM folder and sub folders. Now once the pictures populate simply just select your pictures and either right click to save as, copy or drag and drop them into another folder on your desktop or a specific folder.
Oct 27, 2013 | Apple iPad (16 GB) WiFi Tablet PC
Ipad disabled b/c son forgot his password...help us get in?
If your son cannot remember the passcode, you will need to restore your iPad using the computer you last synced your iPad with. Using the last computer you synced with allows you to reset your passcode and re-sync all your data, apps, etc.
To begin the process, connect the iPad to your computer using the USB cable or lightning cable. Open iTunes and select the restore option.
If you restore on another computer, you can still unlock the device and remove the passcode, but your data and apps will be wiped.
Hope that helps!
Apr 03, 2013 | Apple iPad Tablets & eReaders
How to DELETE more than 1 contact on my IPad
If you have multiple contacts on your iPad and still get no luck in deleting them directly, maybe a third-party iPad transfer program can be helpful. You're able to find various kinds of data transfer programs for iOS devices on the Internet, and I would like to introduce iTransfer to all users of iPhone, iPad and iPod. This software is used for transferring files among iOS devices, iTunes and PCs, and it enables users to manage apps, music, movies, TV shows, ringtones, ebooks, photos, Camera Roll, text messages and contacts with ease. The following guidance will show you how to delete multiple contacts on iPad.
  1. Run iTransfer, and connect iPhone to computer with the USB cable. The software will automatically detect the libraries of your iPhone, and display the libraries in the left sidebar.
  2. Choose "Contacts" library and then the contents will be shown in the right part of the window. Check the contacts you want to delete, and click the "X" at the top of the window.
  3. After clicking the button, you will see a pop-up dialog. iTransfer will make a confirmation of deleting the selected contacts. Click "Yes" to start to delete contacts on iPhone.
  4. iTransfer will start deleting contacts on iPhone in batch immediately. The "Deleting" word will be shown in the middle of the window, and the software will finish the deletion in very short time.
How to Delete Contacts on iPhone
Aug 30, 2012 | Apple iPad Tablets & eReaders
How to connect ipad to my tv
You will need Apple Composite AV Cables to connect the iPad to your television. The cables can be purchased online or at your local Apple store.
You can also stream your iPad to your television if you have an Apple TV by using Apple's Airplay.
Hope that helps!
Aug 10, 2012 | Apple iPad 16 GB 3G Tablet PC
Apple iPad 16 GB 3G Tablet PC Logo
26 people viewed this question
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
