Luminox 8152 chrono
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
