Vehicle Parts & Accessories Logo
A
Anonymous Posted on Jun 29, 2014
Ariane alarm how to reprogram remote control of ariane car alarm system?
Kardoc
Level 3:
Top Expert:
  • Autopage Master 7,501 Answers
  • Posted on Feb 26, 2019
Kardoc
Autopage Master
Level 3:
Top Expert:
Answers
7501
Questions
0
Helped
2755175
Points
58317
3 Related Answers
ZX2Fast
Brad Kirby
  • 547 Answers
  • Posted on Mar 05, 2010
SOURCE: I am attempting to reprogram my remotes. I can not
Is this an aftermarket or OEM alarm? What vehicle if it is OEM.
Most alarm modules will be found near the steering column or vehicle ignition switch.
Testimonial: "You were correct. I had instructions but was not reading them right. Thanks for your help"
Anonymous
  • 19 Answers
  • Posted on Nov 05, 2010
SOURCE: Trying to replace the remotes for my car alarm
We have a you tube video just for you! check it out here:
http://www.youtube.com/watch?v=IrdQRmkHDlI
Good luck to you
Azrael SRL
  • 11800 Answers
  • Posted on Feb 11, 2011
SOURCE: Hi, I've a Bosch remote
If just a remote has failed (the other works perfectly) then the problem is with it, not the system - that remote has died. You will have to buy another one from sites that deal in second hand parts/ classifieds , like Ebay and Craigslist, and reprogram the system to accept it. You will need to provide the exact model number of your system if you want the correct replacement remote and the exact procedure for registering the remote.
If you don't know the model number or you can't find another remote then you will need to completely replace the system. - it won't cost too much, a simple system with installation will cost you less than $150.
3answers
Hey have u tried this manuals site big-manuals.com ? Like manuals are great and for automobile problems it's suggested that manuals should be referred.. I personally like big-manuals.com it's a great website and very helpful.. u must try it once
Why doesn't remote start work?
It says its a Viper alarm system. . If the alarm system is active, reprogramming the ignition keys was a waste of money. The problem is in the control box for the viper alarm system. It has disabled the ignition because it thinks that is being broken into. there are sensors that monitor the the vehicles vibration and is probably a problem with one of the sensors or maybe even the control box itself.
HOW PROGRAM THE KEY LESS ENTRY FOR SONATA 2012
  1. Cars
  2. Car Maintenance
  3. General Car Maintenance
  4. How to Program Keyless Entry Remotes in a Hyundai Sonata
How to Program Keyless Entry Remotes in a Hyundai Sonata By Christian Killian, eHow Contributor
20Found This Helpful The keyless entry system in your Hyundai Sonata is part of the factory alarm system. If you have to replace a lost or damaged remote, reprogramming will be necessary. The remote is important because not only does it lock and unlock the doors, it also arms and disarms that factory alarm when you open or close your car doors. New remotes are available from any Hyundai dealer. While they will program it for you, you can do it yourself and save a programming fee.
How to Program Keyless Entry Remotes in a Hyundai Sonata(Kleophaus Livingston/Demand Media)
Other People Are Reading
Step 1: Locate the fuse panel under the dash on the driver's side of the car. Just below it is the control module for the factory alarm system. Open the cover on the alarm system control module and locate the memory switch inside.
(Kleophaus Livingston/Demand Media) Step 2: Verify that the switch is in the "Off" position; if it is not, switch it to the "Off" position. This is important for the system to understand what you want it to do when you move to the programming mode.
(Kleophaus Livingston/Demand Media) Sponsored Links
Step 3: Insert the key into the ignition of your Sonata and turn the key to the "On" position. Wait for 60 seconds, then move the memory switch inside the control module to "Set."
(Kleophaus Livingston/Demand Media) Step 4: Depress and hold the "Lock" button on your remote for one full minute. This allows the remote and the control module to communicate and sync. Release the "Lock" button and turn the memory switch in the control module back to the "Off" position.
(Kleophaus Livingston/Demand Media) Step 5: Turn the ignition switch to the "Off" position and test the remote by pressing the "Lock" or "Unlock" button, verifying that the doors do lock or unlock.
Read more : http://www.ehow.com/how_6362326_program-entry-remotes-hyundai-sonata.html
2answers
My Acura zdx remote stopped working after my car got towed,alarm went off and I had to use key to stop the alarm . I cannot use my alarm again how can I get back to remote key again?
check your manual for remote programming. may have to reprogram remote control or leave car running so it can all reprogram to factory settings
Remote controll not working not
The best thing to do is:
1- Replace the battery that is located on the back of the remote. If nothing happens then;
2- Try reprogramming the remote control with the car. if you have the original manuals, then it will precisly tell you how to reprogram your remote to successfully communicate with the alarm module in the car.
The problem could also be the Alarm module receiver.
hope that helps. Let me know.
Battery is dead on the remote and cant turn alarm off if i change the battery does it have to be reprogramed?
just replace your battery you have a central control module, that stays programmed, the only way you need to get it reprogrammed is if you take it out and put it in another car
1helpful
I am attempting to reprogram my remotes. I can not locate the Alarm system control module.
2answers
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
I have a car fitted with a Clifford GS 470 alarm but I cant get the alarm to stop. The car that this alarm was fitted in has not been started in 5 months and so the battery ran flat. I replaced the battery...
you might have to replace the batteries in the remotes. The reason why the alarm is going off because once you plug power back to the alarm brain it sets the alarm off and the only way to make it stop is to hit the unlock button the remote. Make sure all connections on the alarm brain are good and try changing the batteries in the remotes. also might have to reprogram the remotes to the brain if it has been sitting for awhile.
17helpful
2answers
Model car alarm APS2K4SAW is not working
have a prestige APS2K4SAW remote and it just quit working, I need help please????
Top Autopage Vehicle Parts & Accessories Experts
John
John
Kardoc
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
