Why it says manual feed load paper
I am a Brother employee working for the software technical support department.
We have a solution for your printing issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000016347
Description of Problem 100000012720
When I try to print from Microsoft Word or another program, I receive a message stating: Manual Feed, No Paper, or Load Paper XX. What can I do?
Brother Software Technical Support
SOURCE: auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
SOURCE: Feeding the paper
press the help button and it will give you print out of basic menu you will need.
SOURCE: paper won't feed from drawer - stuck on "manual feed"
The readout on my intellifax 2820 says, Document Jam, clear the scanner jam, then press the stop key. I can't get it to clear. What should I do?
SOURCE: brother intellifax 2800. Will ring for incoming
check toner... if toner is good then your laser unit is shot...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
