What type of oil do you recommend and what size oil filter does it take?
Use SAE 5w30 oil. I recommend Pennzoil but all major brands are good. You can use Synthetic or Conventional oil. If you use conventional oil change the oil/filter every 5,000 miles. If you use Synthetic change it every 8,000 miles.
Anyplace that sells oil filters can tell you the correct filter. On your Pontiac I recommend you use an AC/Delco filter. Purolator, Wix, and Bosch are also excellent filters.
The 4 cylinder uses a AC/Delco PF47 filter.
The V6 uses a AC/Delco PF457G.
