SOURCE: Compaq nX 7400 Bluetooth device not detected by the system and modem drivers not detected
hi ive got a hp latop nc6120 its been formatted and now i can,t hook up bluetooth devices tried various downloads but this hp gives me a req saying requires bluetooth licence , ive since researched and hp has a built in block in their software which stops you installing windows xp drivers , there is a way round it but its not easy
SOURCE: modem says no dial tone, phone line is ok. Also USB ports wont work with flash drives.
plz check your pc for viruse then post your findings for further help
SOURCE: power surge on usb port
unless your a very competant motherboard components repairer.
this is beyond repair. i,d suggest taking it to a repair centre, where they will replace the motherboard. and unfortunately a large invoice to go with it. probably more cost effective to look at a replacement laptop.
Mike @ Compurepair.
SOURCE: xp drivers for nokia 6300 usb port and modem
Hi Nic,
Go to this site and download drivers for your USB:
http://www.driversupdate.org/?gclid=CJWxyPOpuZoCFQWfnAodUlL4cg
I am not familiar withat Nokia suite. Do you know if it is dial up or DSL? When you press that button, do you hear white noise and then a dialing sound?
If this does not solve all your problems, please reply.
Sirwriter
SOURCE: i have sony vaio vgn-cs14g laptop. i am using tata
First I am unsure of your OS - (operating system) is it Microsoft Vista? XP? 7?
Besides that, I would go to the Control Panel - uninstall the device driver(s) for the photon software ZTE, and the inbuilt bluetooth and web cam, if they are showing 'installed' but the are NOT working.
Then, ONE at a time, starting with the ZTE, download the most current driver or the last working driver you have. Do not attempt any further installs of drivers until you see this is successful.
Once you have installed the driver, this should either work, or generate a specific error. Please reply with the results and we could go from there!
Thank you!
