Connecting Rods: First pass 15 lb ft. If you have an early first design final pass 60 degrees. Second design 75 degrees.
Main Crank Bolts: Inner bolts first pass 15 lb ft. A final pass additional 80 degrees. Tighten the outer bolts/studs 15 lb ft. Final pass 53 degrees.
Tighten the side cap bolts to 18 lb ft. Tighten the bolt on ones side of the bearing and then tighten the bolt on the opposite side of the same bearing cap.
Oil Pump Bolts: 18 lb ft.
Oil Pump Screen Nut: 18 lb ft
Oil Pump Screen Bolt: 106 lb in
Oil Level Indicator Tube Bolt: 18 lb ft
Oil Level Sensor: 115 lb in
Oil Pan Drain Plug: 18 lb ft
Oil Pan Bolt: 18 lb ft
Oil Pan (to front cover): 18 lb ft
Oil Pan (to rear cover): 106 lb in
Oil Pan Skid Plate Bolt: 15 lb ft
If you need more specs contact:
[email protected]
