How to drain the water on the Morgan hot tub
It might be good for you to contact a plumber when draining things like that. That way it can be done correctly and afterwards they could clean the drain as well for you. That is what I would want to do so that I wouldn't have to worry about doing it wrong myself. http://www.manhattansewerdrain.com
Although all hot tubs are built with a way to self drain, the best way to drain and clean any hot tub is with a submersible pump, and a shop vac. If you are a hot tub or spa owner you need to invest in these two items it will save you loads of time and do the best job draining and cleaning your hot tub.
The best time to drain clean and refill your hot tub or spa is the fall just before the winter. You should change your water every three months depending on your usage. Remember to always clean your hot tub filters when you drain and clean your tub.
Draining your hot tub:
We wrote an article on Draining and cleaning your hot tub for the Fall that you can find here. Hope this helps you out with draining your Morgan hot tub.
Hot Tub Fall Cleaning Great Day to Change the Water
If no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
